My 1996 3.9V8i Discovery didn't slow too well in emergency stop situations, so today I checked the pads and the pistons/calipers.
The pads where nearly at their limit, so I replaced them all round.
The calipers/pistons were fine.
I checked that the servo and valve were working OK, and they are.
Problem is, there's no real 'snap' to the brakes (OK, I know it weighs 2 tons and should possibly have an anchor to bring it to a halt) but emergency stops can be hairy.
Weird thing is, otherwise the brakes seem fine. Not noticeably spongey.
BUT, there is an audible 'squish' sound heard inside the car (sounds like from behind the brake pedal) when the pedal is depressed.
I'm getting depressed now.
Is the 'squish' normal?
Can there be air in the system or the brake fluid iffy even with a firm pedal?
Please help if you can.
Cheers,
Ian
Cheers,
Ian
