landlords inspection
10 Feb 2007
Norfolk
hello and thanks to all that answer,
I have a RGI coming to do a landlords inspection on a combi boiler and just wanted to ask if the entire flue has to be exposed? although it is accessible it requires the removal of boxing witch is filled,corked and painted. should i remove it prior to his arrival or wait to see what he says?
cheers.
Ideally yes the whole flue should be exposed for inspection. However its down to each installer and their judgement. Also depends on the flue type involved.
If the flue lenght can be seen with mirrors and is a straight run it may be possible to check the flue sufficiently.
On some coaxial flues it is also possible to sample the air (with a FGA) to check joint integrity.
I suggest you cut inspection ports into the ductwork (large hole saw), since the flue will need inspection each time the LGSR is carried out.
I'd be very surprised if your rgi mentions it.
A Landlord's insprection does not require the full length of the flue to be inspected, nor are there any tests on a normal coaxial flue.
If he has some cause for concern, that's different.
Its a coaxial flue, but there are 2, 45degree bends in the boxing, will this cause any problems?
