Laying Ceramic Tiles onto Concrete
8 Sep 2005
Could anyone help...
Do I need to firstly lay down plywood onto new concrete (in bathroom) before tiling, or can the ceramic tiles be layed straight onto the concrete ?
Provided it is completly dry, not just the surface then Yes you can tile straight to the concrete or is it screed, assume it's a ground floor bathroom.
Jason
Thanks Jason.
Although it's a new build, the concrete has dried.
However, it's situated in an apartment on the 3rd floor - does this make a difference :?:
Thanks.
If they are new apartments then the floor will be beam & block or metal profile with concrete over the top. Either way you can tile straight onto the top.
Avoid the premixed "tile concrete floors" and use a powdered adhesive & separate powdered grout. If you need to use the bathroom the same day go for a rapid set adhesive as this will take light foot traffic after approx 3hrs, allow 24hrs befor grouting.
Jason
