    Dismiss Notice
ldv pilot running badly, misfiring, low on power
Discussion in 'Car Repairs / Maintenance' started by ldvvanman, 16 Oct 2012.
  1. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    hi i got an ldv pilot and when you rev it is missing and smokeing and flat like theres no power there,
  2. Sponsored Links
  3. dannytylerwells
    dannytylerwells
    14 Oct 2012
    20
    Thanks Received:
    Bristol
    Country:
    engine size? year?
  4. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    hi engine is 1900 diesel 2002 year
  5. Burnerman
    Burnerman
    7 Feb 2008
    22,987
    Thanks Received:
    4,470
    Northumberland
    Country:
    Any chance that a turbo pipe has come adrift somewhere? Often the engine makes a deep booming sound if it has.
    John :)
  6. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    hi its none turbo, when you start up and rev it it sound rough and its missing and lots smoke.
  7. Burnerman
    Burnerman
    7 Feb 2008
    22,987
    Thanks Received:
    4,470
    Northumberland
    Country:
    Could be the EGR system that recirculates the exhaust gas for reburning.....
    Failing that, an air leak into the fuel system could be a favourite - particularly if it doesn't like a cold start.
    John :)
  8. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    hi iv disconected the egr system, as for cold starting its a good starter, what happened i had some blocks in the back of the van going up a hill temp gauge was high then it started smokeing and low on power got home temp was ok but blew the water bottle got that fixed and missing and smokeing ever since, hope you understand a bit better now .
  9. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
  10. Sponsored Links
  11. Burnerman
    Burnerman
    7 Feb 2008
    22,987
    Thanks Received:
    4,470
    Northumberland
    Country:
    Unfortunately, that sounds like the cylinder head gasket may have called it a day....is it still chucking its coolant out?
    John :)
  12. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    hi john no temp gauge is normal not loseing water in the oil, so would the head gasket make it miss and smoke.
  13. Burnerman
    Burnerman
    7 Feb 2008
    22,987
    Thanks Received:
    4,470
    Northumberland
    Country:
    I was just a bit concerned to hear that you had boiled the engine under load....thats very unusual these days!
    Anyway, if the problem has occurred since then obviously something has given up the ghost......head gaskets don't always fail between the cylinder and the waterways, but thats definitely the commonest point.
    If you take the oil filler cap off and rev the engine, is there a load of fumes being kicked out?
    John :)
  14. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    HI JOHN NO THERES NO FUMES FROM THERE
  15. Mursal
    Mursal
    23 Sep 2010
    2,203
    Thanks Received:
    484
    Country:
    Ireland
    Fuel filters, air filter and if it overheats pull the thermostat out and see how you go. The fan drive ok, radiator dirty inside or outside?
    And if its still overheating, potential head gasket
  16. ahmotorsport
    ahmotorsport
    18 Oct 2012
    10
    Thanks Received:
    Sussex
    Country:
    I wonder if you've partially seized it.
  17. ldvvanman
    ldvvanman
    16 Oct 2012
    36
    Thanks Received:
    Cornwall
    Country:
    not done that mate it still starts and runs but if you rev it miss's and smoking
Loading...
Share This Page
