leaking bath
6 Nov 2005
Tyne and Wear
hi i have just had a shower in my kitchen!!!! my bath is leaking i have taken the bath panel off and the pipe from the plug hole has come away any ideas how i fix this as there are no screws or anything to tighten it up
Mos plug hole/waste fittings are held together with a central screw. Sometimes these break if the joint is stressed, for example by poorly aligned waste pipes.
The simplest solution is to buy and fit a new bath waste outlet (only a few ££). Can't promise that there won't be other complications (in fact quite likely) in which case you might need a professional.
:cry: :cry: it will all end in tears wouldnt trust the work as described not if you want to sleep at night :!: undo it again and put silicone sealant on both the underside and the bath side of the waste,re- tighten the screw (carefully its easy to break cheap wastes) then wipe away excess sealant from the bath side . Leave to set and if your lucky........... if not buy a decent waste not B*q w**k*s etc but from a plumbers merchant and repeat the process[/quote]
Before you put the sealant down, make sure the joints are dry. Really dry. Otherwise it won't work. The sealant needs a good amount of time to dry before it can take water. 24h should cover any situation.
If all that fails, buy some (plumbers mate) which is like a putty, scoop some out of the tub and roll it like a sasuage and apply it to the underside of the plug hole, then tighten it and remove the access. guaranteed to work.
