Leaking corner Jacuzzi bath. Worth fixing?
14 Nov 2014
Nottinghamshire
We moved into a new house in June and decided to clean the corner jacuzzi bath in the en-suite, as it hadn't been used for a while.
After filling it with water & disinfectant, we soon had water running from the light fitting downstairs.
Obviously there was a leak from somewhere but removing the bath panel didn't show me where the water was coming from. Everything looked dry. The spa pipes were full of black gunk, so it obviously hadn't been used in a good while - presumably because it leaked - our sellers hadn't done any DIY in years by the look of it.
The water must be coming from underneath the bath or from inaccessible pipes in the corner.
I'm guessing the whole thing will need to be removed and checked over. Is that something a plumber would do or is it a write-off?.
If, as you say, 'Everything looked dry' then my assumption would be there is no leak from the bath itself. Is the flooring under the bath complete or are there any gaps/holes where water could have leaked through without any evidence?
Did the water in the light fitting only appear AFTER you had let the water go from the bath, indicating that there might be a leaky waste rather than the bath itself?
If possible, try partially filling the bath so that the water doesn't cover any of the outlets and see if there are any leaks evident. Then let the water go and check again.
However if you are convinced that the bath does leak then up to you to decide if you really want a Jacuzzi. Much overrated in my opinion.
