Leaking mdpe pipe at compression fitting
Discussion in 'Plumbing and Central Heating' started by sastek, 8 Jun 2021.
  1. sastek
    sastek
    2 Oct 2013
    12
    Thanks Received:
    Country:
    Hi, I need some advice about a leak. I recently had a leak from the underground stop cock for mains water, so replaced it with a new one. The problem I have now is that the mdpe pipe is quite loose at the compression tee, I can't get the nut to tight enough for the olive to clamp properly on the pipe. The pipe does have a insert, I've tried using a new olive and a used one that was in good condition. I'm wondering if it has something to do with the diameter of old black pipe vs new blue pipe.
    [​IMG]
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    13,431
    Thanks Received:
    3,104
    Daventry
    Country:
    Almost certainly different diameters. I'd take the tee out and replace it with a Philmac one
    • Thanks Thanks x 1
    • Like Like x 1
  4. CBW
    CBW
    26 Sep 2019
    9,785
    Thanks Received:
    2,678
    North
    Country:
    Iirc black pipe is 3/4”/21mm?
    • Like Like x 1
  5. sastek
    sastek
    2 Oct 2013
    12
    Thanks Received:
    Country:
    The new blue pipe is 25mm, I'm wondering if the old black pipes are 1 inch
  6. polesapart
    polesapart
    27 May 2011
    1,390
    Thanks Received:
    365
    Country:
    • Thanks Thanks x 3
    • Like Like x 1
  7. Sponsored Links
  8. oph
    oph
    20 Jun 2010
    8,788
    Thanks Received:
    1,522
    Sussex
    Country:
    Alkathene which is old hat from the 70s and mdpe on the right.
    Probably needs a transitional coupling to get from either material, not the tap.
    • Thanks Thanks x 1
  9. JohnD
    JohnD
    15 Nov 2005
    75,094
    Thanks Received:
    4,361
    Crossgates, Europe
    Country:
    Cook Islands
    I have black alkathene incoming, and the main stopcock ( a brass one) is alkathene ?one inch? incoming and copper outgoing, quite a common size. I think your bit of blue pipe is the source of your trouble.
    • Thanks Thanks x 1
  10. sastek
    sastek
    2 Oct 2013
    12
    Thanks Received:
    Country:
    Thanks for the responses, they were really helpful.
    So the new blue pipe is the wrong diameter, luckily I've found a bit of old black pipe to replace it with. I also think that the stopcock is the wrong size, it's for 25mm pipe. The manufacturer makes adaptors, so hopefully they work with this stopcock.
  11. JimCrow
    JimCrow
    31 Jan 2011
    675
    Thanks Received:
    235
    St. Kilda
    Country:
    The stopcock you have ( Philmac 3G 2833) does both 3/4" Alkathene and 25mm MDPE pipe, no need for adaptors, use the original pipe you cut out with the olive from the brass compression tee to the stopcock.
    • Thanks Thanks x 2
    • Like Like x 2
  12. sastek
    sastek
    2 Oct 2013
    12
    Thanks Received:
    Country:
    Well spotted Jim, thanks! For some reason I recalled it was a Plasson one.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
