Leaking shower tray help, used fibre glass kit!!!
3 Aug 2011
Bute
Hi
So I noticed last week my shower tray was cracked and started to leak water as my living room had water coming out from sealing.
After reading around I decide to buy the fibreglass resin kit from halfords. I did about 4 layers and the area with the crack feels solid like ice, concrete.
I thought great problem resolved but no on the third shower same amount of water started to leak as before, the fibre glass still looks rock solid so it seems it is not waterproof.
Can anyone please suggest what I can do as at present I won't be able to do major repairs. Did I chose the wrong fibre glass? Is there a coating I can do to water prof it?
Any help!!!
Should be ok used it many times on temp repairs ie baths,showers.
You sure the crack hasn't spread ? did you cover a good area around the crack ?
yeah it is covered 3-4 inches either side of the crack. I mean it still feels rock solid, this happened last night late when my misus had shower so havent had a chance to look at other things.
It might possibly be leaking from else where so will check on it again this evening when i get home.
