Leaking toilet - Pan connector or pan?
29 Aug 2007
Bournemouth
I have a toilet with a concealed cistern in a cabinet. I often find water on the floor which seems to come from under the toilet bowl. I have taken the removable panel off and the floor inside the cabinet is dry (bottom edge of cabinet is siliconed) so the leak must be at the pan. I dont think it is coming from the flush pipe (flexible type) as it feels dry where it joins the pan so I think it must be the waste. It has a short, straight pan connector which goes into a very short piece of pipe and then into a horizontal T. The T then runs about 30-40cm slightly downhill and joins a vertical pipe. Everything seems to fit fine and I wonder if its possible that the pan has a leak.
Any advice gratefully received. Many thanks in advance.
Does it leak all the time or when you flush?
If only when you flush, it would suggest either pan connection or flush pipe problem.
