Hi lads , I have a the above cooker and was looking for a bit of advice on one of the parts. The fault is the fan oven , timer , ignition all are kaput. The conventional oven and grill still work fine. There are 2 thermal cut-outs on this , one supplying power to the conventional side and one to the fan oven , timer and ignition. All is pointing to the thermal cut out on the fan and timer side. Question is , where is this thermal cut-out located. Have found the conventional side handy enough , but the other one not so easy. Is it necessary to remove the ceran hob to access it? Any advice would be welcome , cheers.
