Length of waste pipes
14 Jul 2005
Cornwall
Hi all,
Can you advise please?
I am installing an en-suite bathroom. I intend to use 40mm waste pipes from the basin & bath/shower, Is there any regulations concering the maximum run of an internal waste pipe or soil pipe?
Chris
32mm =1.7 metres
40mm =3.0 metres
If you are going straight into the stack you need anti vac traps.
You can extend these runs if you protect with AAVs :D
I thought 40mm was 2mtrs but I'll take your word Bacho. Anyhow, (2 or 3) is your running longer than that you should go to 50mm.
Good link Chris. :D
I have been told that going straight into the stack could lead to loss of trap seal and is always best to allow air in.
I'll take your word for it. :D
My understanding is that anti-vacuum traps would be required if the normal limits on branch length and gradient could not be met, or if more than one appliance was connected to a waste pipe. In general any situation where syphonage (self or induced) would otherwise occur. ;)
