lighting in the attic
19 Feb 2006
West Midlands
hi
i want to fix some lighting in the attic
planning on daisy chaining two light sockets together and fixing them to seperate rafters.im ok on the wiring for that
what i want to do is then pick up a cieling light fixing,say the bathroom to get power and then route it down to a 20 amp neon pull switch that im planning on fixing to the ceiling in my bedroom behind the wardrobes out of the way
it needs to be a neon pull switch so i can see at a glance wether the lights are on in the attic or not
anyone describe in laymans the wiring schematics please.
im gonna get it checked by a spark when its done
thanx jon
see for reference - loads of pictures there of basic lighting circuits.
had a look and the only diagram close to ,is one by breezer but its to a junction box,not old rose to new rose and not with its own on off neon pull switch.
also would the pull switch have to be inbetween the two roses?in the new circuit
the electrical switch supplier also said that if you wire the pull switch wrong the neon light is on permanentley
thanx again
Take a feed from the loop. Connect to the "feed" terminal of the DP switch.
Attach another to the "load" terminals of the DP switch. Connect other end to light fitting.
Job done!
