lighting wires above or below acoustic mineral wool
23 Jan 2010
Sussex
I want to replace a 1978 Artex plasterboard ceiling with Soundbloc plasterboard on resilient bars and 100mm of acoustic mineral wool.
  • Do I run the lighting cables next to the plasterboard or on top of the mineral wool?
    Do I need to increase the conductor size?
In general and if possible cables should be run on top of insulation to avoid derating but if it's 1.5mm cable on a 6A MCB then they will be fine under 100mm glass wool.
Cables normally go above insulation where possible, but for a 6A lighting circuit it won't make any difference.
That reminds me - as an unqualified DIYer, I don't think I can modify the consumer unit (old fuse box). Is it normal to retrofit modern consumer units to 32 year old wiring?
In theory, anyone can replace a consumer unit, provided they notify building control first.
In reality, changing a consumer unit is not something the majority of DIY people could do or should be attempting.
A new consumer unit on old wiring is certainly possible. 32 year old wiring could be perfectly fine, totally ruined or anywhere in between.
Assuuming it is 32 year old wiring in good condition, then I don't see why not.
I'll probably get the consumer unit replaced when I get the final safety check done (unless I find anything). It was last checked about 20 years ago when I had the plumbing strapped.
Also, are bathroom pull switches still used? My step-son's new build in Leeds has the bathroom switches on the wall out in the hall (very inconvenient). I shall be extending the small bathroom when I remove the airing cupboard and water cylinder. I'll need to move the pull switch.
Yes, pull switches are fine. They seem to have gone out of vogue a bit these days, but nothing wrong with them.
