Hi!
I've had the Linea 28 installed for about 4 years. A couple of years ago it started giving the message 'CO' when I turned it over from Heating/hot water to just hot water.
The boiler fires and the pressure just keeps on rising!
Now, it's started doing the same when I turn it from hot water to heating/hot water. It's been fine all summer with just the hot water setting.
If I turn the knob back and forth just a little, it goes to normal, and the 'CO' disappears.
I rang Vokera, but they didn't know either.
I don't want to know how to fix it, I'd just like to know what the problem is before I call out an engineer.
If Vokera don't know, then an engineer could charge more than the boiler's worth to find/fix the fault.
Any of you guys come across 'CO' before?
Thanks.
John
Thanks.
John
