Was having problems with boiler firing as soon as power and also a whoosing banging noise
I have changed the programmer to a lp722 which seems have fixed the boiler comning on on its own
I have also fitted a new drayton MA1/679 valve which seems have stopped the whoosing and banging
Question is the small lever on the bottom of the valve should it be hanging down or clipped up? its up latched atm? seems to be just heating water any time heating is on stat on cylinder is set at 55 but its lot hotter than that
Also the boiler doesnt seem shut off when room stat says should i have taken the room stat off which is a drayton didgistat 1
On the wall plate red is in no1 , no2 is empty and 3 is yellow there is a blue wire tucked away i take it this is correct but are the other 2 right way round?
The boiler is a myson apollo 30b
