Hello,
i plan to put laminate flooring in my frontroom & hallway, i purchased the flooring from wickes, its the fix 15, which is tongue & groove, it also has a v effect in between boards....id like to know:
1) should i use glue in the living room/hallway to join them up?
2) the underlay i have is the green boards, the floor is concrete & then has vinyl tiles on them? should i remove the tiles? or leave them?
3) room has wooden skirting, should i remove this?
4) what is the gap i should keep between the wall & the laminate?
5, should i carry on the flooring into the hallway or put something under the door?
your help is appreciated..
thank you.
thank you.
