- Joined
- 16 Mar 2005
- Messages
- 51
- Reaction score
- 2
- Country
Hello,
I would like to floor my loft, I already have loft insulation in place. The problem is that the loft insulation sits about approx 3'' above the 5'' joists. Is it OK just to floor over this and squash it down or will this lead to condensation problems? I will not be flooring the full width of the loft, probably about 65 - 75% of the width
I will plasterboard about half of the loft walls and ceiling but there will be at least 3 or 4 feet all the wall around it for ventilation. Just concerned about the floor.
Should I go for a thinner loft insulation, put a vapour barrier below the existing loft insulation, use rockwool slabs, which I believe are thinner but just as insulating, or some other option?
Andrew
Andrew
