Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I use my loft a lot and i keep leaving the light on. Can anyone recommend a light switch type/make with a neon indicator to remind me when the light is on.
Cheers
I have a pull cord switch, and tied a big white curtain ring on the end, it hangs just above the hatch opening so it is the first thing you see when you climb up, and the last when you climb down. If I didn't have such high ceilings I would be able to reach it with the hook on the loft ladder pole.
I used to have the same problem with leaving the outdoor floodlights turned on (they're not visible from the front of the house where the lounge/ bedrooms are). In the end I bought a 240V panel mount neon from RS, cut a rectangular hole in a single gang blanking plate to take it, and connected it to the outdoor lighting circuit. I mounted it just below the ceiling so that it always caught my attention when it was on...
