loft light
19 Jun 2010
Hi
Can anyone give me a diagram showing how to wire up a light in my loft? :?
Turn off the power to the circuit you are working on and test that it is dead.
Find the nearest ceiling rose to where you want to place the lamp.
At the ceiling rose run 1mm2 T&E from the live loop, the neutral loop and earth loop to a single gang switch. At the switch place the live conductor in Common - place the neutral conductor in a terminal block and the same for the earth unless there is an earth lug available.
From the switch run 1mm2 T&E to the lamp. At the switch connect the live conductor into L1 - the neutral into the neutral terminal block and the earth into the earth terminal/lug.
At the lamp put the live to the live terminal, the neutral to the neutral terminal and the earth to the earth terminal.
A junction box in the circuit cable leading to the rose may be easier.
If it is easier you could come off a socket circuit and use a switched fuse spur to operate. All depends on what will cause less disruption or preference.
why add an unnecessary junction box to the installation?, take it from the rose
Easier connections.
May be shorter cable (Us DIYers tend to have odd bits of cable rather than a lovely roll.)
There may be a cable convenient to the loft hatch, and then a deep socket box could be used to contain all the connections including the switch plate.
Domgen, if you are going to do a job do it properly and professionally.
You don't use junctions boxes unless you absolutely have to, especially in lofts where there is insulation. There use simply creates another potential high resistance area where a fault could occur.
Your plan to utilise a ceiling rose is the simplest approach to take - do not use a socket spur unless you absolutely have to. You will probably have to chase out or make holes in your plasterboard to achieve this.
If there are issues regarding location of the switch you can always use a pull switch instead of a wall plate switch.
Hi
Work your way through these:
You're asking that question not because you don't have a diagram, but because you don't understand what to do - if you did you would have no need of a diagram.
Doing electrical work without a genuine understanding, i.e. just replicating a diagram without knowing why is a bad idea. Diagrams are great ways to explain things, and to learn from them is fine, but if you find yourself needing to refer to one for something as trivial as adding a light then you don't actually know enough.
Riveralt, soon to do a similar job myself:
Do you mean put the neutral into a choc-box??
Kind Regards.
