Hello
I have 2 flourescent lights in the loft, at this time they are on a normal 13 amp plug into a socket and work on a movement sensor.
Im not happy with this set up, and it was used when some work was carried out in the loft.
I would prefer to have them wired into the main light ring.
would it be ok to have a spur off the ring for 2 large lights, I have an electrician coming to do a consumer unit in a week, if i attach the wires to the lights ( a pain and time consumming as they are high and awkward) and leave the tops off the lights all he needs to do is check they are connected correct and join wire to the a switch and then on to the spur.
The loft is used for storage, but we do go in it often, may be 4 times a week.
Im just checking as its alot of wire and a pain in the arse job if its not acceptable on the day.
thanks
OJ
thanks
OJ
