    Dismiss Notice
Logic combi 35 issue
Discussion in 'Plumbing and Central Heating' started by Mark Jefferson, 18 Jan 2020.
  1. Mark Jefferson
    Mark Jefferson
    18 Jan 2020
    Thanks Received:
    Country:
    Hi all.
    I currently have hot water but no heating.
    Pressure is fine, although it does seem like I have a very slow leak on the boiler and a week ago I did come home to 0 pressure. But right now, pressure is ok, in fact its at 2 which may be a tad high. But it was a little lower (1.5) earlier and still wasn’t working.
    The clock hasn’t kept the correct time on there in a long time, it would always be out of sync after a couple of days. However I did try setting the timer this afternoon which was the first time in a few months and so seems like quite a coincidence that it is has now stopped working.
    I’ve got it in the correct position on the settings, in fact I’ve flicked back to constant and of course tuned up my thermostat, which is how I normally use it.
    I’ve tried resetting and turning off at the wall.
    When I have the thermostat turned up, the boiler does show “c” which means it’s recognising the demand for central heating, but none of the radiators are warm.
    Any suggestions?
    Thanks.
  2. Sponsored Links
  3. DP
    DP
    10 Dec 2003
    14,791
    Thanks Received:
    3,251
    Glasgow
    Country:
    Proper boiler service would be my first port of call:whistle:
    Once that is done, fault the sequence to find out what is amiss
    Regularly see boiler that have been serviced yet front has not come off the boiler
    • Like Like x 1
  4. Garfeild
    Garfeild
    19 Jan 2007
    1,282
    Thanks Received:
    171
    Kent
    Country:
    check you haven’t accidentally turned off one of the heating valves (Black ones left and right hand side) when you repressurised.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
