Looking for a guide to using push fit Polypipe
26 Aug 2007
Cumbria
Hello all,
Im a home diy'er with quit a bit of experience using copper pipe for plumbing & soldering etc.
I would like to start using the PolyPipe push fit stuff,
Does anyone know of a good guide to using the stuff?
I'm guessing its pretty easy to use, Im just not sure about all this insert business.
Plus im going to be using it for alterations to my central heating system, and my hot/cold supply to kitchen sink.
So if anyone can point me to a good comprehensive guide that would be great.
Polyplump do manuals!
Bear in mind that the warranty of all this placcy pipe is conditional on the outside of the tube not being scratched during installation - it compromises the O ring seals in the fittings.
If you want to take advantage of the warranty you may want to protect the parts where you will be jointing, during the drawing in process. For instance, using PVC tape.
avoid speedfit from john guest it will fail in about 6 years the fittings go brittle on heating and hot services
Hep2o also has problems with the grip rings not gripping properly
plumbfast and polyplumb - personally never had any trouble with either of these
Do you have statistics to support this, or is it just that you've come across some? I have, which is why I check and discard every faulty grab wedge. Do you not do that? :eek:
They're not bad, but nowhere near as easily demountable as Hep2o Acorns.
I have never like those pastic push-fit fittings, I use speedit caps etc, for temporary connections but thats it.
Tectite lads!! Metal, solid, expensive, demountable, un-undoable.
Job done
Kill all ******!
