Looking for fixing - no idea what it's called
11 Dec 2019
I've bought a Brenton bolt fixing. I will be drilling a hole for the bolt to fix into but I'd like to line it with a plastic or steel liner. However, I have no idea what this "hole protector" is called
Any help welcome
Regards
Tet
pipe.
buy a bit of pipe that will be a loose fit for the bolt (internal diameter) to allow for the door sagging or moving, and drill a hole that is a close sliding fit (external diameter) for the pipe in the doorframe or whatever.
verify that it fits, and after cutting to length, secure the pipe with a little builders adhesive.
Copper pipe is very easy to cut if you have a pipe cutter. On an outside door or gate, you need something that will not rust. Stainless steel is quite hard to cut by hand. Aluminium is very easy. You might find an ebay vendor that will sell you, say, 1-inch lengths neatly cut to size.
If you want a strong fixing, you can get a staple (keep) for a door lock, set in a rectangular strip so it can be fixed with four screws.
I did once manage to get some to take a round bolt, but have never seen them again.
Thanks John
Great idea. This is a fixing for a garden gate and the bolts (2) will be taking the weight of the gate.
The pipe idea is genius. I'm going to use 15mm speedfit pipe as the smaller internal diameter will be great for the 10mm deadbolts.
When I went searching for a circular cover I found that I am looking for an escutcheon. This will take some of the weight and finish the hole nicely.
Interestingly I turned up a "hafele escutcheon" and a "ferrule escutcheon" which are what I was originally looking for, but your idea is a definite improvement- thank you
Regards
Tet
