Looking for suggestion on garden fence.
14 Mar 2006
Essex coast
Will be mounted on top of low wall , problem is wall curves into gate post on one side( 2/3 being straight) and on the other side the wall curves all the way . Around 18m in all.
Also want to match the same type of fence where it returns to house but no wall there so will need to be approx double the height of that on wall.?
Im sure that all makes sense to you having seen it but its hard to get a handle on what your describing or asking?
With curved fences I have used 2x1'' slats vertically. The problem is more the splayed rails, i hav had some success with relief cuts on the rear and bending it round. The main issue is trying to get a consistant curve over 2 rails so you cant really overlap the rails easily.
How tight a radius are you talking about?
On a straight run, you could do the supports at 6ft, but as the wall curves, you'd need to narrow the distance between the supports to a length where the straight fence above the curved wall is acceptable to you.
