Low Energy Daylight lightbulbs
19 Jul 2004
Normal low energy lightbulbs run at a temperature of 2700K to produce a yellowish light. You can get low energy daylight lightbulbs (www.yourlights.co.uk) that simulate the light of the sun at noon but they run at a temperature of 6000K.
If I fit a daylight bulb will I need to replace my lampshade in case it gets too hot?
No, a 60w daylight simulation lamp won't put out anymore heat than a 60w 'normal' incandesant lamp, colour temp is a different thing to temperature
this is the same all the way through the thing, 100w incandescant - 100w daylight incandesanct, 15w CFL - 15w daylight CFL
...2700 degrees kelvin, and the lamp would be a puddle of molten metal and glass... :lol:
Typical colour temperatures are:-
High pressure sodium lamps: 2000K to 2200K
Tungsten filament lamp: 2700K
Tungsten halogen lamps: 3000K
Fluorescent lamps: 2700K to 6500K
Metal halide lamps: 3000K - 5600K
Daylight: 5500 - 6500K
If you fit a 6000K fluorescent lamp in your house, unless you need that colour temperature for technical reasons you will be appalled at how harsh it appears.
They are also considerably more expensive than the 2700-3000K range.
