Bit of a problem!.The pressure gauge on my boiler is hardly moving,on the display it is only showing at best 0.9 bar.Used to show 2 bar.Is there anything i can do/check my self befor calling an engineer out? Many thanks.
Lost all pressure now down to 0.3 bar fault 22 now flashing on display!.Water pressure to the boiler appears to be ok!.Central heating and hot water now not working.
So you're loosing water pressure, but where? Out the discharge pipe from the PRV (pressure relief valve), internally in boiler (e.g. AAV - auto air vent) or from system pipework (typically around spindle of radiator valves?
