Hiya all,
Am wanting to install some low voltage deck lighting outside.
Have currently taken a spur off a mains socket (which is 30mA RCD protected) using 1.5mm T&E to a 3amp FCU and from that using 1mm T&E to a light switch. I currently have same 1mm T&E running through outside wall to nothing (no fuse in FCU at moment so no problem)! I was planning to run cable under deck through 20mm conduit to a transformer which is designed for outside use and house it in waterproof box or whatever making sure all joints are sealed. However, I'm not sure I should be using 1mm flat T&E outside (all waterproof cable connectors seemed to be designed for round cable).
Am open to suggestions for a better setup, but:
- want to use the inside light switch to switch low voltage lights on and off
- could replace the 1mm flat T&E running from outside to light switch with something different if necessary as it is running through conduit buried into plaster
- would prefer to keep transformer outside.
Help please! Ta
Help please! Ta
