I think I'm near a conclusion now!
It looks like an unvented is my most recommended option and we've gone through all the pro's and cons of the different approaches of combi/storage combi/heatbank/unvented.
We still seem to have borderline flow though in terms of an unvented.
Static pressure - 2.2 bar (goes up a bit from that with time of day)
Dynamic pressure - 1.3 bar (when above was measured)
Flowrate at 1st floor bath tap - 20l/m
I need to know if there's much difference between makes/models for unvented at that sort of flow. I've been unable to work out how much loss of head to expect when pushing water through an unvented?
I'm assuming it's similar to what happens with pipes for example going from 15mm to 22mm to 22mm looses a lot of pressure, but worse - this might be completely unfounded though.
There also seems to be a large variance in coil performance and I'd have thought the higher the coil rating, the cooler the return temp and therefore the more efficient in reheat times and in condensing?
e.g. for 150l size models Megaflow has 12.5kW coil, Ariston Prima has 26.7kW, Range Tribune is 18.9kW.
If this is true and we'd lose more than a bit, would a thermal store with a plated heat exchanger (e.g. DPS pandora, range flowmax) or a coiled heat exchanger (e.g. Albion Mainsflow) lose us less flow?
I realised the plated versions are more complicated and come with anti K.I.S.S moving bits to go wrong and the Albion wouldn't deliver anything like an unvented in terms of maximum flow, but has less to go wrong with it.
I just want to maximise what we have in available flow and pressure.
