Mains water pressure
29 Oct 2004
Does anyone know roughly what the average mains water pressure is in pounds per sq inch?
I'm trying to work out how high I need to site a water tank to supply collected rainwater around my garden at a reasonable pressure. ie close to mains as I can get.
My plan is to link numerous water butts to a central very large elevated tank. The water from the butts would be gravity fed to a central pump which would lift the water into the elevated tank for storage.
The elevated tank would then feed outside taps place around the garden on demand.
kevplumb said:
anything beetween 15 to 50 or higher depends on the local water co
Lovely thanks KevP
(By the way thanks for all your help on my last visit. Your advice was invaluable and my waste swimming pool water venting system is working a treat). :wink:
Oh dear that means to reach a lowly 15 psi I need to elevate the tank to around 10 metres!? Does that sound about right?
bathjobby said:
Saw a newspaper advert the other day for a submersible garden water butt pump i.e. throw it in the butt with your hose attached and hey presto. Wouldn't this be a cheaper / better option assuming you have the garden space for the ground level butts ?
Sorry can't recall the newspaper, but a there are a load of them here too;
http://webshop.keyind.co.uk/is-bin/...-/GBP/WS_FrameSet-Product?SKU=MM74222[/QUOTE]
Nice one thanks.
I was intially thinking of using a pumped system but I quite liked the idea of maybe using a single small pump running on off peak electricity to fill an elevated tank. I could then use the stored water at my leisure without using any further power, assuming I could generate enough pressure.
The garden is about one acre and we are thinking about putting in some underground irrigation. We've got a lot of roof space and a lot of water butts which are currently largely unused. They currently contain some very dodgy looking water!
A concern has to be not only the height of the butts if you want to draw down using gravity but also the weight the water will put on your structure. You may well need an engineer to calculate that and check that your current structure is strong enough.
Good point... fortunately I'll be constructing a new garage block and intend to put the tank in the loft space. Unfortunately it looks like I'll be building the worlds tallest garage!
If your going that high (double storey almost) to get the pressure you want, seems a shame to do so just for the tanks. May as well better utilise the space (planning permission aside for a moment) and go 2 storey with some sort of accommodation, office, etc above the garage with the tanks/butts in that loft space.
Indeed, I keep saying to myself ...water tank or snooker room...hmmm
