Mattress and Condensation
19 May 2006
I have a small box room where only a divan bed will fit and due to the make up of the room it has to go against a cold external wall.
The wall is covered with a wallrock liner which has made an improvement however it is difficult to stop the mattress from touching the wall and creating condensation/damp.
Is there anything I can place against the wall to prevent the mattress touching it direct but that won’t still create condensation? By this I mean I have tried polystyrene but still then get condensation between polystyrene and mattress. Or is it just a case of every morning pulling the mattress slightly away from wall?
30 May 2013
West Midlands
Do you have a radiator on in the room during the day/evening? Also, does condensation go on the windows too? Does anyone use/sleep in the room or is it a spare? It's unusual for a spare room to get so much condensation.
24 Oct 2020
Cavity wall insulation will help if ever you get offered it for free but the only way is to create an air gap. Polystyrene sheet is cheap from DIY and will help but you said you tried that.
30 Dec 2018
If someone is nightly using the bed, then mattresses absorb lots of moisture during the night from the person sleeping in it, which is why it is usual to air the bed and bedding during the day. If that is the case, then the only way is to pull it away from the wall each morning.
