measuring french windows/doors
D
diane1
:D hi there, could somebody tell me how to measure french windows, is it around the brick work or the inside measurement?
i knbow this sounds a bit stoooopid but i know it is a 4 foot widefrench window that i already have but on b and q and wicks websites, all the measurements are completley different!!
please help....ta
diane
16 Apr 2007
Measurements are done from the outside...brick to brick.
Is it Timber or UPVC french doors your buying
D
diane1
hi, its upvc, the one thats in is wood but its split and u can see day light, its been screwed shut for safety for over a year and they have some special offers on in b and q
hows that 4 womens logic!!!!
why are there so many different sizes for height????
diane
16 Apr 2007
your opening is 4 foot which is 1220mm metric size.
Most 4 foot UPVC doors come in 1200mm width allowing you 10mm play either side of the brickwork.
If i remember right BnQ's 4 foot doors were 1200mm wide and you have to allow 2100 in height including bottom sill (BnQ doors dont come with bottom sill by the way).
As a side note some BnQ stores are doing specials on 4 foot UPVC french doors at the moment for £134.
26 Apr 2005
Don’t forget all replacement windows/doors must be notified to BC (fee involved) if you don’t use a FENSA registered installer! If you don’t get a certificate of conformance from one or the other you may have problems when you come to sell; it’s a pain but that’s how it is!
26 Apr 2005
diane1 said:
sorry to sound thick, but who is BC????
diane
You local council Building Control; they are responsible for supervision, inspection & certification of all notifyable building work & replacement windows fall into this category.
D
diane1
mmmm. thats something else to think about!
thanks for advice, how long has that been around or has it always been a rule?
diane
26 Apr 2005
diane
Not entirely sure, since around 2002 I think. IMO, I think it makes sense to use a FENSA registered company if your only doing one or two windows as it saves all the hassle & the fitting charge should only be around £50-60 a window (a little more for French doors) & BC will probably charge more than that to inspect & certify. I was going to fit my whole house out myself but in the end decided that for the comparatively small cost (to the cost of the windows) of having it done professionally it didn't make much sense + you get a 10 year warranty! I have fitted the odd window here myself, it's not difficult but it will take you much longer if you don't do it every day + there is always the risk you will mess it up.
It rather depends on your budget & what your looking for but I would suggest you look at some other products as the B&Q stuff is, er how shall I put it, very budget! Avoid the big nationals, they mostly overcharge but small local companies are very competitive & often use the same products.
D
diane1
ooooooooooooo to late, have just been out and bought b and q one only £113 i guess you get what u pay for but i will just be glad to be able to open the door as its been screwed shut for ages for safety as its gone past its "best before date" haha.
anyway...................thanks for all your help guys!
lets hope the rain stops by weekend
diane
