Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have a Megaflow CL170 hot water system. When I run the cold tap warm water comes out for quite a long time. When it eventually runs cold it is still not as cold as I think it should be. Any ideas as to what the problem is ?[
How long have you been getting hot water from your cold taps.
Since the cylinder was installed or only recently? has anything be altered or "repaired" on the system. Are there any other symptoms ie: running at the tundish. Is the clod fill to the cylinder hot?
We have recently moved to the property and it has always been like this.
Is the tundish the plastic bowl with open sides with copper pipes each end ? If it is then there is no sign of any water dripping. Is there a non return valve that could be faulty and letting the hot water into the cold water system ? I have never come across this type of system before.
I think that the inlet is the one that has a blue disc on the cylinder, if this is the case then this pipe is warm. I have talked to the tech department at Magaflow and they think it is the Cold water combination valve at fault. Do you agree with their diagnoses ? I also believe that the plumber will have to be specially qualified. What qualification should he/she have?
