Micron 120FF main burner fails to light
19 Oct 2008
London
Micron 120FF. It goes through starting sequence, the igniter lights the pilot, neons 1 to 3 light up but the igniter keeps firing, the pilot is still alight but the main burner doesn't light.
When I remove the cover from the boiler then the main burner lights and neon 4 lights - the boiler appears to run normally.
Does anyone have any suggestions for diagnosing the problem. The fault chart suggests the PCB but as the burner lights OK when the front cover is removed it seems unlikely to be an electrical fault - more likely something to to with a pressure switch or similar.
TIA
Unfortuntely this needs an RGI in to fix. Should be a simple fix for him.
Sorry to be vague and not give the answer, but you should not really be delving this deep into the boiler.
