Mini Expansion Vessel?
Discussion in 'Plumbing and Central Heating' started by ukheather, 16 May 2009.
  1. Joe4542
    Joe4542
    21 Jun 2007
    405
    Thanks Received:
    96
    Bedford
    Country:
    As per posts above - they want a mini EV, to take up any expansion / water hammer effects on the cold mains/DHW circuit, likely due to customer being on water meter.
    Water meter installs usually (always?) include a check valve in the circuit - therefore WB dont want high static pressure caused by suddenly closing the tap to blast out a seal from the plastic waterblock.
  2. Sponsored Links
  3. nickso
    nickso
    30 Oct 2006
    6,722
    Thanks Received:
    302
    Country:
    guess it is mandatory then. :LOL:
  4. kevplumb
    kevplumb
    18 May 2004
    23,712
    Thanks Received:
    925
    depends where i get sent
    Country:
    twas fun thou ;)
  5. screech
    screech
    21 Oct 2008
    747
    Thanks Received:
    149
    Countryside
    Country:
    it's only really new boilers that may need them to stop the boiler leaking as they just aren't made like they used to be! it's not really to prevent water hammer but just to cover up the fact that the boilers leak too easily! ;)
  6. harryhound
    harryhound
    6 Apr 2009
    9
    Thanks Received:
    Essex
    Country:
    Just for the record:
    I bought a house in the country, with a Worcester kerosene (Paraffin-oil) boiler about 10 years old.
    I did the calculation that I had more bedrooms than people and decided that a water meter was a sensible option.
    Nobody told me that water meters incorporate a non return valve.
    So when I turned on the boiler for the winter its "slave-tank" of hot water [Paraffin does not have enough heat to work like a natural gas combi] duly expanded and the rising water pressure had a choice of squashing the diaphram in the mini expansion tank or trying to back-up into the rising main.
    Well the mini expansion/knock preventer thing the size of a swan's-egg-cup, had not been re-pressurised in the 10 years, as the previous owner had no idea of how his boiler worked.
    The mixing valve in the boiler (which gives priority to the hot water) burst its gasket - fortunately the boiler is outside of the main house - and it was my wallet that took something of a knock.
  7. Sponsored Links
  8. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,757
    Thanks Received:
    1,005
    Durham
    Country:
    I was reading up on this recently as part of my mains hot water via plate heat exchanger plan- with any closed heating or hot water system there is the possibility of expansion of heated water causing excessive pressure in the pipework. Back in the day that excess pressure would be sent back down the water main, nowadays with backcheck valves it needs to be catered for in house. Only needs a tiny vessel cos overall dhw pipework volume will be v small- 20, maybe 30 litres in a big house- cost me £15 i think for a 2 litre vessel.
  9. Ltnman
    Ltnman
    16 Apr 2008
    163
    Thanks Received:
    3
    Bedfordshire
    Country:
    I have just taken out a WB Maintenance contract on my 12 year old boiler, as it is starting to get old. They asked no questions.
    As for the water meter, I was just given one a few years back, no checks no nothing.
  10. ukheather
    ukheather
    21 May 2004
    155
    Thanks Received:
    Country:
    I posted this thread 11 years ago lol.
    Might be better to start your own if you need support rather than bumping a 11 year old thread? lol
    • Like Like x 2
  11. rhinosaw
    rhinosaw
    22 Jul 2017
    358
    Thanks Received:
    4
    Country:
    Do u still have your hair?
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
