Mira electric shower overtemp
16 Feb 2007
Merseyside
As the title says i've got a mira sport 10.8kw electric shower and I keep getting the overtemp light coming on.Water pressure hasn't changed any ideas?????
a friend of mine had a similar problem and it was the cable size that was too small. Do you know what size cable you are using?
Have you descaled the head recently?
And I don't mean just the outside of it - generally the only way is disassembly, so that you can remove the loosened debris that otherwise sits inside the head.
Er, what? Are you asking me if you're getting good flow? :?
I was saying yes I've cleaned the head and i'm getting good flow through it.
I have the same problem. Water flow excellent (unchanged) - flow is too good to suggest that it is the head that needs descaling. Overheat comes on when Medium or High setting.
Power cable to the unit is a big fat cable ... cooker size. Not a problem of power as it has worked for years too.
