Hope someone can help.
I have a Mira Go thermostatic Shower, this has been fitted for about a year.
It was an excellent shower with good pressure. In the past about 3 times you could turn the shower on and no water would come out. If you left it for a couple of hours it would then work. Now there is no water at all.
The pump is running. I am not any good at this, however I know the water is getting to the shower as I removed the inlet filter plate and water was present.
I turned off the water at the mains and cleaned these filters. When i put it back together i left the plate slightly loose and turned on the shower, as i said the pump appears to work, as i could hear the air escaping then the water came out of this plate.
It would seem to me that water is getting into the shower but it is not coming out. I have disconnected the shower spray plate hose and nothing from there, so it can't be the shower head.
It seems it wont allow water past the inlet filters or whatever is next in line to them.
When i say the pump is working the motor is sounding and the fins spinning.
Can any one give me some idea as to whats wrong.
