shower is a 8.5kw replaceing a 10.5kw, existing cable is 10mm, however the cable from the switch to shower unit has been damaged, as this section of cable is easily accessed I am tempted to run 6mm from the switch to shower to enable easy terminating, would this be hazardous given that the cable from fuse to switch would remain 10mm therefore mixing the cables.
