Moving a radiator to the other side of a door
3 Jan 2008
Birmingham
I want to move the radiator in my dining room to to the adjacent internal wall. Unfortunately, there is a door in between meaning that I can't just run the pipes (8mm microbore) around the skirting.
Am I able to extend the pipes from where they connect to the existing radiator and run them up and over the door?
Or...should I intercept the pipes on their way down the wall and run them along the top of the door and then down?
The walls are dry lined brick.
Any advice gratefully appreciated.
Imagine you are a Slug.....
of AIR :lol: .... Stuck in a pipe that goes up and over the door.
Once you got above the door; would you want to go back down to be let out at the radiator?
Er no I don't think so. You would want to go back up to be let out at an upstairs radiator wouldn't you?
If you sit above the door that pesky water will be rushing past you all the time and you would gurgle as you drown in it.
Now that way is much kinder to Slugs :D
