I need to move a door frame along by 10cm. I read the previous post about removing a door frame, but this door is situated in what was once an exterior wall (it is now the door between the kitchen and the classic flat-roofed bathroom extension on the ground floor at the back of a victorian house).
The walls are stripped back to the bonding coat
I literally need to slice down the right hand side and move over the frame and fill in the gap to the left.
Should I now dig around above the door to find out if there is a lintel and if it is wide enough to slide the frame over without requiring support?
What would your next move be?
