multi fuel stove
5 Mar 2009
Gwynedd
hi i have a multi fuel stove and when opening and closing the doors they make a squeeking noise,i know i can not put grease or oil on because of the heat but would like to know if there is anything out there i could use to get rid of this squeeking.
cheers tom. :roll:
Or a light smear of copper grease on the pins; it’s used in many applications to provide lubrication in high temperature applications & the copper stops the squeaks.
A dab on the back of brake pads will also stop those squealing as well. :wink:
Thanks to all for your suggestion's i will try them all and see which works the best.
cheers Tommy. :roll:
:idea: Copper paste - for lubricating parts and bolts that have to sustain high operating temperatures, operating range from -30deg C to +1300deg C
