Hello,
My Radiators have not worked for 2 days, although I have noticed that a buzzing noise has been coming from the airing cupboard where the boiler is. I have turned up the thermostat, messed about with the ON/OFF switches/timer in the kitchen, all to no avail.
I have just seen this white box on a pipe coming into/out (?) of the tank called a Myson Power Extra. I decided for whatever reason to move the switch up the side of it and within a few mins, I had heat ! I let go and the switch moved back down again and fortunately the radiators have remained ON. Perhaps this is the equivalent of banging the TV when it doesn't work, to find it 'mends itself'.
Can this be explained and what do you suggest ?
Also, If I had a radiator leak, which I haven't (touch wood), how do I turn off the water going into the radiator system/tank. I guess that a pipe comes out of the tank (top or bottom ?) that supplies the water to both upstairs and downstairs (one pipe or two ?). I know that I have 3 red taps near the tank (somewhere amongst the many many many pipes) so I guess one of these will do the trick. Any suggestions ?
Natasha
Natasha
