Need concrete repair help
15 Nov 2022
I have a two piece bird bath that belonged to my Grandma. It is well over 50yrs old and has developed a crack in the bowl.
The bowl is approximately 80-100lbs and about 1-2in thick, the crack started on one side and now goes across. On one side the crack is all the way through and the bird bath is leaking all of it's water in one-two days.
I stood at Home Depot and got cross-eyed trying to figure out which stuff to use. Some of the "fixes" require making the crack larger(I don't want the bowl to break). I found one that you could use on swimming pools but then you need to seal it. The sealant comes in one gallon quantities!
I also do not want to use anything that will harm the birds.
Any ideas of what to use?
15 Nov 2022
I also do not want to use anything that will harm the birds concrete repair Salt Lake City.
thanks in advance for any help
22 Nov 2009
Oldham
This is an English forum - you'd probably be better on a domestic one due to differing product available.
3 Sep 2006
West Mids
Use a silicone mastic product (in a tube used with a caulk gun) to seal cracks. Clear or stone colour
Use an epoxy cement product (powder in a bag or a box) or in a tube like toothpaste to fix chips.
Use an epoxy adhesive to stick bits back together
You may need to break the bath to then stick it back together, depending on how bad the cracking is.
