Need help on identifing part on ferroli 77ff
9 Jul 2005
Birmingham
Hi all, my boiler started to leak water very badly this morning and have found the culprit but i dont know what its called. the part is a silver ball with a tyre valve on it which screws into the water inlet to the boiler. it has no wires to it. thanx jim.
Was a Ferrroli service agent but I can't recall this part. Sounds like a mini shock arrestor/expansion vessel.
Yes it is a expansion vessel thank you. found out by searching the web, now i need to know if it has to be boiler specific or will any one fit with the same rating as i have no hot water and two grubby kids lol.
I should search the web, worked last time.
Any expansion vessel (potable) will work, but if you want it to fit then the OEM part will be best. You won't get one today.
OM is about £60 and a 8lt external on which i knopw is a bit big is only £18 so dont know what tomdo ,ill have a think
