I'm just finishing refurbishing my 1st & 2nd floor maisonette in London.
A new 32mm water supply was fitted by Thames Water (previously 3 flats shared the one supply.) The plumber put the stop cock on this in the communal ground floor level cupboard where it previously was, reduced to 22mm copper and ran it upto the 2nd floor where the Megaflo / Worcester system boiler are. From here it feeds 2 bathrooms, a WC & Kitchen.
In the 3rd floor bathroom tap water pressure is only just over 1 bar, and the flow rate is 10 litres per minute. It makes the large Hansgrohe shower head a bit of a joke. It's pretty much the same on the 1st floor bathroom too. Kitchen tap on the 1st floor seems much better but I need to get this tested.
I've had a couple of new plumbers look at the installation for advice and have been told different things. (Original plumbers don't work for the main contractor anymore and he's dragging his heals getting someone else in to check.)
First guy said the 32mm pipe should have been run up all the way to the top floor and this would have increased the flow rate substantially. Didn't really have any comments on the pressure.
Second guy said this was rubbish as the pipe is reduced when it reached the megaflo anyway, and reducing to 22mm on the ground floor increases the pressure too. He said the only thing to do was fit a header tank on the roof & pump.
The pressure is over 3 bar to the ground floor flat in the building which is on it's own new 32mm supply as well (reduced to 22m at the same point in the communal cupboard. I don't know the flow rate yet.) My Megaflo is around 10m up from ground level so I don't know why I'm losing 2 bar in pressure, and am confused about how to try and get a better flow rate too.
If I'm missing any information needed to help please let me know and any help is greatly appreciated!
Jay
Jay
