Hi
Just completed building an extension to my home, complete with overspend, and my 11 year old Baxi Barcelona appears to have died. I am looking for a decent replacement. Owe my in laws a few thousand quid but will be able to re-mortgage next year to cover that and the new boiler. I found the old Baxi very good for the heating system I have installed. We live in a 4 bed chalet bungalow, built 2002, with about 230m2 of floor area.
The Baxi had been leaking one day and not the next for a few weeks now and my plumber couldn't diagnose the exact problem, always dry when he took it apart. However the past few "colder" days, since Sunday, the leaking has been every morning, not afternoon, until today when it was dripping every 3 or 4 seconds into a bucket when I got home at teatime. The pressure had dropped a little. I took the casing off, unscrewed the 1/4 turn screws and removed the outside cover of the heat exchanger. I could see the condensation trap was not overflowing and there were regular drips from two points at the bottom of the heat exchanger - bottom left corner and half way along the bottom lip. I called my plumber and he asked me a few questions before diagnosing that the heat exchanger is probably leaking and it is time to replace the old Baxi. I will miss that explosive ignition !!!!
I have underfloor heating upstairs and downstairs in my home. There were 2 separate Unipipe manifolds (5 loops dowstairs and 3 loops upstairs). There is now a third manifold for the extension and garage conversion (2 more loops). In addition the boiler needs to provided hot water to a megaflow cyclinder.
However we did discover when building the extension that the original boiler is not conventionally wired in, or so I am told. How i explain it is the cylinder in the boiler keeps the water hot all the time and ready to be pumped from the manifolds, even when the manifolds are not calling for heat. I think the plumber said there is a permanent live to the boiler / the manifolds are not switched to the boiler. The manifolds call for heat when needed and they pump the water through the underfloor heating system. All i know is it works and the boiler intermittently fires up even when the stats are up to temperature. (i hope this is clear)
My plumber has suggest a Vaillant boiler but is also happy for someone else to fit a replacement as he is booked for the next two weeks.
My father in law had a Pro Combi Exclusive 30 installed about five months ago and is pleased with it. However his view is it was cheap, about £500, and he doesn't expect a boiler to last more than 7 or 8 years.
Looking for a recommendation that will best suit my current set up and run as it is wired and plumbed in now. Messing about with the electrics in a major way is really not an option.
Thanks and sorry if I have rambled....
