Have a 3 bedroom midterrace house with two double rooms and one box room. Two rooms downstairs with one to be converted to a bedroom - this is why the current back boiler will need to go. We current have a 450x900 cylinder.
6 people in the house and approx will be having 9 rads. Hot water in kitchen would be used at the same time as someone taking a shower / bath.
We have ruled out the combi option due to the breakdowns people experience and possible flow issues.
The options we now have been quoted on (we told both that we require a lot of hot water and that our current system keeps running out of hot water and recovery time is also long) :
1. Sealed unvented system
Valliant 624 boiler
Valliant unitstor 210l ( I am thinking of requested the 180 but not sure if its better to go with the larger one?)
No tanks in loft I have been told
Approx cost is £5200 including all new CH pipes plus 22mm gas line to boiler.
2. Open vented system
18KW boiler (baxi or Valliant are options - any recommendations?)
450 x 1200 Range cylinder (160 ltr)
Existing cold water storage will be used but they said they can fit a pressure vessel to provide better flow to the new rads on a long run into the kitchen (which is far from the cylinder). Can you do this with an open vent boiler / system?
Approx. £3800(baxi boiler) OR approx £4000 (valliant) + £550 if new CH are requested else system flush is included.
My Questions:
a. based on my house - 3 bedroom (1 bathroom), 6 ppl etc - is a sealed unvented system excessive and only used in multiple bathroom properties
b. do people still install new open vented systems or is it better just to go for the sealed unvented option?
c. based on my quotes above what should I do, as I am confused about what is best for us. I sometimes lean towards the OV system, but then think its an older type and the unvented is the way to go? But then fear at the same time that the unvented system is more prone to failure. The unvented plumber said it is down to installation, which I agree, but I cant help but feel that there are more parts to go wrong....PRV, PV etc.
As mentioned, we are very confused about what to do, typically you only update a system once and its a big cost so we want to get it right.
Any help and advice is greatly appreciate.
First post so if this does not belong here, or I have done something wrong, please politely tell me.
Valliant 624 boiler
My Questions:
