New Dimension Gas Fire Installation
1 Sep 2015
Note: This isn't about a DIY install, just the work needed
We've currently got a Kinder Oasis Gas Fire with a Chimney Flue. Dimension wise, the first is 250mm deep and 485mm wide.
What we were planning to do is your media wall, but remove the existing fireplace and hearth and replace with one of the hole in the wall types Example A and B. Fireplace would be slightly recessed, and we'd build out the existing wall slightly to accommodate a flush fit TV & soundbar, hidden wires, lights etc.
Does anyone know if the types of fires I've linked above usually just fit into the existing chimney space, or if a more heavy modification of the brickwork usually required? Alternatively, could the wall be framed out further, and the fireplace be brought forward with some sort of flexible flue liner used (seems like a no, but worth asking)
The house itself was build in '95. Picture of current layout
CS2Zg5xAIVW2y-WWrKTWNNSKZJY2yHSQzk7ng2vcnLbLDUhEo0WlzCavi_vpEpxsBUk-E-iAnvhmsgrHxpqaMGGIRR28ibr15hRkRqkxbdt244ZiE3UCMGXvAMpfvZw2n_6MiaXkEi_UDRa_E7ZdAKxZ0xAIJVRqaMRQ2rvlRO1zmimEEgBozwb71-gemdJayJTxMudO7oTiH74eiFmqtEKxvqzPwVl0cuFbJyfMyJa6yFYL1EWX6B-55XmKAMu4KKj0SJbcpDBsA5Xculpt-w8uXoq80R0ySgLaZCkgLXqsHdVjsCV4CGntjL00Sys4e0t5I6s-7q29nWgqck7vTVqnCVJzrt5SDSfKS-0_dtTOu20RnYEXWoOiUILP8ie1wbyTEFo5E8Z1IaPDzYvuipednaeovcuT0Y4uwC8gbFMuIgbdNNFQMuTErfrdRVV9K9siRlZ86yyW1hABBYguwE8xhae3GYVH7Vx0kIrYwvOfx3dJ2hRE2poRlTFvfNIr1nUeWK3ZcNK_4O2FS_HC9qQObKS39Bf9L0EIUSD9d-Deg21Ycs6xliyhDYObdfk3u5iZJW8ARTUJGiGfpxX9Iz3HeOiAJtexm_Er4fLVm-BSWbEe2oVRrDbDSBighHgweWRrRQLaL1MYpZA91I4hv2DkfeJK90wYKxFgJGxpd4Bnot_9K2DaI74m0rJ8JyYSpD29KMAXSuYdtZyk3MY44majjA=w1289-h970-no
Check if your flue is a class 1 or a pre cast flue most property’s the age of yours are pre cast,a lot of the set up like your go with electric fire as it’s more suitable with TV etc
Yeah its a precast flue.
We'd like to try and stick with gas if possible as the running costs for them are quite a bit higher!
