Apologies before I begin on the rambling nature of this post. Moved into my house a year ago an it needed an emergency re-wire. All done and certified but we didn't really have a lot of time to think about what we wanted and now the missus wants the light in the bathroom changed and a fan fitted. So, it's the type of job I think I can cope with except the MCB bit (more later) and I would just like a bit of advice before I get onto LABC.
I currently have a single ceiling light with a pull cord which I plan to change for 4 low energy downlights all rated at IP44 (smallish room, bath no shower, that's downstairs, ceiling height is 2.4m), with the switch outside the door on the landing. I also want to put in an extractor fan above the bath. The fan is also rated at IP44 but will be in the roof space anyway, the switch will also be outside the door and an isolator will positioned outside above the door. We want to be able to run the fan independently of the light.
Now come the questions;
1. Can I use a 2 gang switch for both the light and the fan or is it better to use separate switches.
2. I will be running everything off the lighting circuit so I think I need to protect this circuit with an RCD. It is not currently, so do I get my electrician to move the MCB in the consumer unit or replace it with an RCBO? I think moving it might entail new bus bars as its a split load unit but consumer units are too scary for me so I don't look in them much.
3. I've drawn a circuit diagram (sorry if it's messy) of what I think it might look like and would welcome comments on colours, sleeving whether it's safe or anything else.
4. Do I need to do anything special as regards earth bonding.
Finally if I'm talking out of my a**e, let me know and I guess I'll have to fork out for a professional.
Thanks.
PS - earths not shown for clarity
Thanks.
