New grout different colours
4 Sep 2013
Hertfordshire
I have recently had my bathroom re tiled but the Ardex fkexible grout used has dried different colours. In some places it's dark grey and in other a lighter grey (almost white). What caused this and can I do anything about it?
29 Aug 2015
Did you get a his solved?
I have the same problem and finish of grout looks exactly same as your picture.
24 Sep 2016
Not a tiler but the assumption is it was not mixed correctly before applying?
1 Oct 2015
It looks like effloresence (salt residue). Normally happens if there is too much water in the mix or excess grout wiped off too soon or the sponge was too wet.
Should clean up easy enough using a mild acidic grout residue remover, like the HG Extra or LTP grout stain remover.
L95
6 May 2016
Too much water in the mix or washed out the grout joint when cleaning.
