New Office/Posters Opportunity (Electronic)
2 May 2007
Hi
I am currently in the process of refitting my office in my home and was going to purchase some posters to put up, knowing me, I am likely to get bored with them and will end up changing them a lot.
I've seen the Samsung Frame TV which looks ace but quite an expensive solution although it would fit the bill. I would not require the TV though, just the arty bits it can do which got me wondering.
Since (from what I can see) you cannot buy an A3 digital frame cheaply (or at all) - the biggest ones I have seen are around A4 at best.
Could this be done buy purchasing a few cheap (ish) televisions and actually seat them inside of the wall I will be building so that the screen is just visible?
Anyone ever seen or done this before?
I have not tried it, but you can put photos/images on a USB stick or the USB HD and display them on my LG TV sets.
doable but what if the tv goes wrong and you cant find another one the same size for the hole
was looking a PC monitors to do this but not too sure how i can connect them all up.
I'm using an IMAC at the moment which i would like to use to control these, what i am hoping is that i will be able to put a hdmi into each monitor and then output them to a box like the above (probably 4 of them) and then i can hopefully connect that up to the imac on the desk and control from there
the four way one I linked to above is similiar to the one I used. I was told "just buy the cheapest one available as the are all the same and come from the same factory but the box colour might change" So I did as told and my ones have fed hdmi round the house for years via 15m cables as well!
How do they look on the computer? are they just an extension of the desktop?
